Channel List
  • sparkyteddy1971
    • Mar 2014
    Channel List
    Hi All
    I have updated the latest channel lists and sometimes, when I update the lists onto a box, In the favourite list it says Entertainment, Sports, Movies etc and sometimes it just gives fav group 1 down to fav group 25, how do I get the proper listings that identifies each particular group please?
    The list is the latest of AJsat
    Thanks for your help
  • mahrkpat
    • Jun 2012
    • 510
    Take this peice of advice from sattv5
    My Favourites are all wrong since I loaded your list how do i fix them ?
    The way to get The favourites under the correct headings is to load the default Database:
    On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
    The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order
    • sparkyteddy1971
      • Mar 2014
      Thank you for your advice
      I will try that. much appreciated!!!
