Hi,I have just set up multiroom 1 box in living room works fine the other box upstairs in bedroom says no signal any help would be appreciated.Thanks folk
no signal
Hi. Have you tried the downstairs box upstairs to check if LNB cable is working ok??? If box works ok then nothing wrong with LNB connections and maybe a problem with your second box or incorrect setup.
Regards.Comment
Hi Nutsandbolts thanks for your quick reply will try your suggestion 2morrow and will let you know how it went.Cheers M8Comment
Hi m8 tried your suggestion fault was bad lnb connection,all sorted now,thanks for your replies.CheersComment
