skybox f5 working great on virgin but not on sly keep rebooting on sly
  • paul93
    • 50
    skybox f5 working fine on virgin but when i plug in to my friend house who has sly it doesnt work keep rebooting what it could be any help will be appriciated.
    Doesn’t make any sense
    • mark8393
      • 2305
      Probably issue with connections on coax, check and redo as necessary
        No need to keep posting the same question: http://www.digital-kaos.co.uk/forums...4/#post2264730
        • DW190
          • May 2012
          • 1263
          Power the box off and remove the sat feed. Power on without the sat feed and see if it reboots then.
          • paul93
            • 50
            yes it reboots without the sat feed checked everything
              Get a new box and this time keep away from F5s your problem solved.
              • Hadron
                • 2102
                Disconnect all leads except the power supply. Does it still keep rebooting? If not, connect the other leads 1 at a time to see what's causing it to reboot.
