Latest Channel Lists - Missing Sky1HD,SS1HD,SS2HD
This topic is closed.
  • saratoga48
    • Nov 2013
    • 9
    This really has me scratching my head so i'm hoping someone can help.
    I have the latest firmware, and have tried the latest version of AJsat's list & SatTv5's list. I have deleted all channels, factory reset etc, I have loaded channel lists many times and am conpletely competent in doing so.
    The strangest thing is happening however, regardless of which list I am using, I am unable to receive the following channels;
    Sky 1 HD
    Comedy Central HD
    Sky Sports 1 HD
    Sky Sports 2 HD
    At The Races
    Racing UK
    Heres where it gets stranger, if I use the listed Sky Sports 1 or 2 (Alternatives) listed at the bottom of both AJsat & SatTv5's lists they clear fine, also if I remove any list and do a blind scan, I can find versions of the channels that work - with the exception of Racing UK which appears to only have one option, which won't clear.
    It 'appears' that all the channels have adequete signal strength 76%+, and 85%+ on a few - so all normal there.
    I'm getting all the movies fine, all the sports etc etc, it doesn't appear to be an entitlment issue with the servers card as surely I wouldn't be able to clear the channels using alternate frequencies... and although it seems like a frequency change issue, surely others would be complaining if the latest versions of the lists were not pointing at the right freq for Sky 1 HD & Sky Sports etc...
    I'm using a Skybox F5s if it's of any help (anticipating many "it doesnt work because it's crap" comments - but its worked fine for me for months and does everything I want it to... Until now.
    Help please, I am well & truly stumped.
  • mark9271
    • Jan 2014
    • 33
    hi try these i have updated this
    also this http://www.digital-kaos.co.uk/forums...update-410429/
    • saratoga48
      • Nov 2013
      • 9
      Hi thanks, I have already tried the original and your updated version yesterday, but to no avail.
      • mark9271
        • Jan 2014
        • 33
        that's weird as i have just tested them both on my f5s and all working fine,which way did you flash the new firmware
        • saratoga48
          • Nov 2013
          • 9
          Using latest firmware direct from skybox.cc, have been using for months with no issues - updated via USB.
          • mark9271
            • Jan 2014
            • 33
            u sure ur box is original and not clone
            • saratoga48
              • Nov 2013
              • 9
              Certain
              • mark9271
                • Jan 2014
                • 33
                sattv5 has a new list out so try this one m8t
                • saratoga48
                  • Nov 2013
                  • 9
                  http://www.digital-kaos.co.uk/forums...1/#post1980897
                  Still the same problem - this is really strange!
                  • mark9271
                    • Jan 2014
                    • 33
                    r u hard wired or wifi
                    • saratoga48
                      • Nov 2013
                      • 9
                      Hard wired, and networking is my job - I'm cisco CCNA certified... It's not a connectivity issue
                      • hkphooey
                        • Apr 2010
                        • 232
                        I had similar issues but mark9271 updated list helped me... There seems to be something very odd happening at the moment
                        • mahrkpat
                          • Jun 2012
                          • 510
                          I think the F3s,F5s seem to have issues with certain channels don't know if its hardware related or firmware notably babytv, geo tv, sony max coul this be related to that.
                          • mark9271
                            • Jan 2014
                            • 33
                            ok i just reverted back to old software on the f5s and put 2 channel list back on to test and all r working 100% and as i never dump or do backups onto my usb, i think when you do this files get corrupt as it dumps them onto ur usb but that's just my opinion,if when i do revert back or do upgrades i delete all manually and flash box
                            • saratoga48
                              • Nov 2013
                              • 9
                              Thank you for your suggestions.
                              I have now resolved the issue myself. Incase anybody else should be experiencing the same problem, what I found in the end was that the Mgcamd plugin in the latest version of the firmware seems to have issues with the Newcamd protocol.
                              If like me you are an N line user (newcamd), simply remove your line from Mgcamd, and use the Cccam plug, switching the protocol selection to newcamd.
                              Problem solved.
