slybox f3 no ip addy
  • mdt
    • 3034
    ok so i have a f3 here was working on 28,2 east and while watching a movie bang! no internet connection. before anyone says check your u no what its not. ive tried upteen firmwares through usb,rs232 ect. the box works perfect apart from the lan feature although both lights are flashing. i cant get a connection via the lan tool either. i know these boxs are cheap crap but i would like to fix it and im just grasping at straws now to see if anyone has fixed the issue on theirs,regards mdt
  • andy91
    • 3583
    Have you had a butchers in you're router settngs to see if its being blocked? Had that on a mates even though it worked at the beginning.
    Think I looked in DHCP settings just to see If any ip conflicts.
    They are cheap crap hence all the latest posts just lately though I did think the F3 was the better crap.
    Andy
    • andy91
      • 3583
      Another thing I don't suppose you're using homeplugs? Had a similar problem when homeplug was in a gang and wouldn't work so would also go direct with Ethernet to router.
      I'm guessing you have tried these suggestions but you never know.
      Andy
      • mdt
        • 3034
        already tried and its not showing up in the router as connected and there are no conflicts via fixed or dchp. a dm500s connects using the same ip addy. i am not using homeplugs its a direct connection,regards mdt
        • cunny
          • 4915
          Im guessing you have tried a working ethernet cable?
          If you have, do you have a ethernet tester tool.
          If you have, connect to box see if all 8 cnnections work. Im guessing ethernet socket has gone
          Sent from my GT-P5110 using Tapatalk HD
          • DW190
            • May 2012
            • 1263
            Have you tried to connect with a USB wifi dongle? Had a similar issue a while ago which turned out to be a faulty ethernet port and the box workd fine with usb dongle. Your near to me if you need a usb wifi.
            [url=http://www.aliexpress.com/wholesale?SearchText=f3+lan+port&catId=&initiative_id=SB_20140401110548]Shop f3 lan port online - Buy f3 lan port for unbeatable low prices on AliExpress.com[/url]
