Help with favourites?
  • CvrPaddyCvr
    • Mar 2014
    • 17
    Hi I have Sattv5's list and for some reason my favourites don't come up as they should. Instead of Entertainment etc the only thing that comes up is fav group 1 etc...
    Anybody have any idea on how to fix it?
    Cheers, Paddy.
  • bigade1
    • Oct 2013
    • 340
    Taken from the FAQ in Sattv's List Sticky:
    My Favourites are all wrong since I loaded your list how do i fix them ?
    The way to get The favourites under the correct headings is to load the default Database:
    On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
    The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order
    • CvrPaddyCvr
      • Mar 2014
      • 17
      Cheers mate, probably should have read the topic before posting. Thanks again!
      • fazz69
        • 160
        do a factory default then upgrate by the channel list by usb and rebot box
