Since messing around with epg stuff i'm starting to get Freeze ups when switching between stations (having to pull the power out) to restart. Ive took the usb pen out with epg on and its still happening, also tried deleting and re installing channel list with no effect ... i did back up the info of the box before adding the epg update (Fxsbackup.abs) & (C.cfg) which are on a different spare usb pen , is there a link on how to wipe the box and put them Back On via that same usb pen .. Getting the box back to its original state , Thanx
Starting again putting files back on box !?
Tags: None
With official latest firmware release, I always do the following when installing new firmware as I had random freezes ages ago when I once did a firmware upgrade.
Backup everything like channel list and other things you need.
Restore defaults
Reboot
Upgrade firmware (do NOT choose to keep dbs and settings)
Reboot (if it doesn't automatically)
restore defaults
upload previously known good channel list and all the other things you backed up before firmware upgrade
reboot -
Restore defaults
Reboot
restore defaults
reboot
EDIT: Probably not the right way to to do it , but ive Just put the usb pen in and loaded Fxsbackup.abs over the other firmware Seems to of fixed it .... Will have to leave of the 7 day epg and the 1 hour fixLast edited by PutTheFootieOn; 14 April, 2014, 07:58.Comment
