f5s crashes
  • supercicciosat
    • Apr 2014
    • 5
    f5s crashes
    Hello everyone and sorry for my english, after setting the file double c, as soon as I connect the antenna cable locks! before doing the procedure was working normally I restarted several times, but just changed the file double c crashes though after the gate. I also tried to use xc but nothing changes nothing all blocked. I was wondering it is possible to physically remove and reinsert the file double c?
    tanks
  • mahrkpat
    • Jun 2012
    • 510
    Isn't it just networksettings>camd settings> client settings manage and delete?
    • supercicciosat
      • Apr 2014
      • 5
      already done but nothing changes! someone told me that this problem is because I used lan tool
      • bigade1
        • Oct 2013
        • 340
        I had the same issue but managed to fix it by making a new blank file using notepad and using the Lan tool to replace it. Others have had the same problem. Read the following threads which may be of help to you and report back if it works for you :
        • supercicciosat
          • Apr 2014
          • 5
          tanks.... i try but not resolving :-(
          • supercicciosat
            • Apr 2014
            • 5
            hello!! albeit with some delay, I want to tell you that I solved the problem! with a firmware received directly from china, this firmware only works with null modem serial cable, you can not install this firmware with usb
