F5S - No signal on H channels
  • andy17x
    • Oct 2013
    • 8
    Last night I noticed I have no signal on all H channels. It was working fine yesterday morning.
    I know this is to with with LNB, however I live in flats so this would be hard to fix.
    I have 2 sat input ports in my flat, one I get no signal from at all (Sat 1) and Sat 2, which has been working fine up until now.
    Any ideas?
  • ColinsPlace
    • Apr 2014
    • 14
    I had this on all my boxes , just reset to factory defaults with the ABS files , reloaded sat scan channels , & internet & code file , then they work the only prob , I got now is no favorites , but switching between V & h channels is now fine & ok
    • bbb_uk
      • 429
      If you have another knowing good box (or original box) you could try to rule out whether it's your LNB/dish/cabling. Failing that, can you take the F5s to somewhere else that you know works fine and try it in there.
      • andy17x
        • Oct 2013
        • 8
        I have been playing around trying to get the No Signal channels back to no avail.I backed up to usb and tired factory reset - although I am not getting $ scambled on pay channels (and no signal on Sports etc!) any ideas what I have done incorrect?
        • earney
          • Apr 2014
          • 14
          I had exactly the same problem, ended up being a faulty lnb. No way around it apart from replacing it.
          Sent from my SM-G900F using Tapatalk
          • andy17x
            • Oct 2013
            • 8
            Not got another box, and nowhere else to take it.
            As said I live in a block of flats, I don't know where the communal dish is - although I can see one from my bedroom thats on the perpendicular building joined on to me. Was working Thursday morning then not Thursday night.
            Sounds far too much hassle, I've had a good 8 months with the Skybox, so I've taken to plunge just to get proper Sky installed next weekend, so if its an LNB fault I'm sure I'll find out then!
            • earney
              • Apr 2014
              • 14
              Yeah, I'm sure if it's the lnb everyone else would have the same issue even if using a normal sky box? Unless a skybox works differently somehow in receiving channels. But as you said if there's a problem then the sky man should resolve it, you could even use the skybox as a second room
              • andy17x
                • Oct 2013
                • 8
                Noticed a works van with ladders in the street and two guys going back to it. Had tired when I came in from work and still the same, but tried now and working again!
