Skybox f5s recording
  • earney
    • Apr 2014
    • 14
    When I record something on the skybox where do I find my list of recordings to watch them? Also the pause feature does not seem to work. When I press pause it pauses the video but audio continues. Only way to get out of the pause is to press menu then exit.
    Sent from my SM-G900F using Tapatalk
  • pgreenie1
    • Feb 2014
    • 41
    You record to a usb stick or external hard drive
    the pause won't work as you have no hd with skybox so it won't pause ..
    • earney
      • Apr 2014
      • 14
      I have a USB pen plugged in. Now it's only 1gb and saves the epg OK. Should it not pause OK even for a few seconds until the USB fills up?
      I know it records to the USB but how do I watch back what I have recorded?
      • pgreenie1
        • Feb 2014
        • 41
        Go into settings and multimedia and it will be in there .. Unfortunately no .. It's only a cheap sat receiver so no capabilities of live pausing ..
        • andy4
          • 1125
          You need a decent size usb stick to rec as a lot of storage is used on usb especially when rec in HD, to find what you've rec press menu>scroll left till you see Media Player>click on that>scroll down to Record then what you've rec will be on right hand side>highlight what you want to watch & press ok
          WIGAN ATH the BLUE BRAZILIANS
          DWSTADIUM the theatre of SCREAMS
          <<<<--------if i've been helpful hit the Thanks button
          • earney
            • Apr 2014
            • 14
            Cheers I'll check that out. Knew I needed a larger USB as I used to have a blade box and it used a lot of memory. Was just testing with my 1gb :-)
            • Chriskend112
              • Apr 2014
              • 5
              What I did was. I got a 1tb external drive partitioned it in to 2x490gb then formatted them to fat 32 I use one for recording and I use the other one for the tms ie pause live tv. On hd u get about 4hrs to 32gb.
              • earney
                • Apr 2014
                • 14
                Is there a setting to tell the recording where to save to then?
