upgrade file mismatch
  • jc69817
    • 138
    hi guys a mate of mine is trying to install the sky order channel list but he keeps getting this message. He is using my memory stick which worked fine for me. Is he doing something wrong or is it a problem with his box ?? Thanks for your help it is a F5s box
  • bigade1
    • Oct 2013
    • 340
    Sounds as if he's not doing the upgrade correctly. Taken from AJ's FAQ in his channel list sticky and a very important point to note is that when he's selected the file that he's upgrading he must make sure that he either presses the yellow button or the OK button so that a tick shows next to the selected file:
    FAQ
    How do I put this list on to my box?
    Firstly, before any upgrade you should always backup! Once you've done that;
    1. Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
    2. In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
    3. Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
    4. Once the upgrade has completed restart your box & voil?!
    • jc69817
      • 138
      thanks pal. Ill get him to try again
      • jc69817
        • 138
        ended up doing it for him but happy days all done
