Skybox f3 keeps reloading
  • Les vagas
    • Oct 2013
    • 6
    My skybox keeps reloading, any ideas what the matter is and can anyone advise me on what firmware update it would need and also a guide how to do it as I'm not that savy at computer/sat box milarky? And what I need to back up beforehand
    Thanks in advance
  • digicon
    • 8261
    Everything you need to read is in this thread here: http://www.digital-kaos.co.uk/forums...-cable-233298/
    • Les vagas
      • Oct 2013
      • 6
      Thanks digicon much appreciated
      • Les vagas
        • Oct 2013
        • 6
        I've tried everything but when I click next it says wrong file?
        There are 2 files
        Any ideas please?
        • digicon
          • 8261
          You have to download the approiate firmware for your receiver and not the 2 files that are in the Folder from the program itself.
          Firmware is ****tered about all over the Open/Skybox section
          • edevs
            • Aug 2011
            • 55
            just flashed skybox f5s make sure u use latest abs firmware with Erom upgrade software
            • Les vagas
              • Oct 2013
              • 6
              Do you have a link to the required firmware for a skybox f3?
              • digicon
                • 8261
                Have a look in the download section: Firmware - Downloads - Digital Kaos
                • Les vagas
                  • Oct 2013
                  • 6
                  Hello again
                  I've tried downloading the required firmware update but can't find a programme to open it I unzip the folder but can't find anything to open the folder with
                  Any help?
                  • Dazzler3693
                    • Oct 2013
                    • 6
                    Originally posted by Les vagas
                    Hello again
                    Any help?
                    I had the same problem mate when I moved the box into a different room. My problem was I had the cable screwed into the box too much, I simply just loosened off the sky dish cable and cut the central wire which was sticking out quite a bit plugged the dish lead back in and just didn't screw it right up and away she went hopefully yours is a simple one buddy too
                    • Les vagas
                      • Oct 2013
                      • 6
                      Cheers mate but mines a firmware issue
                      Might ditch it and buy another
