Skybox f5s no signal on all channels
  • Muddym2002
    • Jun 2011
    • 7
    Hi all
    my f5s was working fine but all of a sudden it's stopped working and displaying 'no signal' on all the channels including fta. Signal strength only shows 5% on receiver. But my other f5s works fine in same setup. Have tried factory reset,new firmware etc but still can't get it to work. Any suggestions?
    thanks in advance
  • digicon
    • 8261
    The So called 'Gift' has no bearing on whether or not your Receiver will work, All receivers no matter what make or model should give you all the Free to Air channels if not then you either have a problem with the Dish/Lnb combination or your box is broken
    • Muddym2002
      • Jun 2011
      • 7
      My gift hasnt expired. Dont think the boz is broken as mrpips on this forum had the same issue and managed to fix it. Just need some clearer instrctions from him :-)
      • mahrkpat
        • Jun 2012
        • 510
        Have you looked in installation to check if lnb is set to ON and not some how got switched to OFF.
        • Muddym2002
          • Jun 2011
          • 7
          Will give that a go mate
          • Muddym2002
            • Jun 2011
            • 7
            Lnb is switched on. I checked the antenna setup on a working skybox and copied it over to the faulty one.noticed that on the faulty skybox the transponder changes from 11720 h 29500 to 10847 v 23000 even though I have set it to correct setting. There is no save option here to make sure it stays on 11720 :-(
            • digicon
              • 8261
              also make sure the LNB setting is set to 9750-10600
              • Hadron
                • Nov 2012
                • 2102
                The transponder setting shows the frequency of the channel that the box is tuned to, so it is constantly changing.
                • Muddym2002
                  • Jun 2011
                  • 7
                  I backed up the working receiver and settings and installed that on the faulty box . still no luck. Any more suggestions?
                  • jerico2048
                    • Apr 2013
                    • 10
                    Its either the cable feed going in or the sat tuner in the box that's at fault...
                    Try this
                    1) turn the box completely off
                    2) remove the sat feed from back
                    3) re-insert sat feed
                    4) turn box back on....
                    Suppose u can check the feed from another working box?
                    I keep my original sky+ box connected up (Freeview channels) so I can check if I have a signal issue from time to time...also EPG
                    • Muddym2002
                      • Jun 2011
                      • 7
                      Try this
                      The cable feed is fine as have tested a working receiver. so i guess the issue is with the sat tuner :-(
