tried aj channel list no good tried other 1 that worked for about 4 hrs then no signal again ?
help please f5 no signal tried the other threds
If it also happens on free channels it could be your LLB naked!!!!!!Tools owned: Hammer, Chisel, Crowbar, Punch, Chainsaw, Cutter and Brain!!!
Note:All information given is to be used for educational purposes only and should not be taken seriously. -
Hi. How can it be the Internet if you dont even get the FTA channels??. Why dont you try a different box to see if its your receiver thats playing up. If second box plays up as well then check dish/LNB/cables are all ok and secured etc.
Regards.Comment
Hi. Not familiar with your type of receiver but the green light is probably your ON/OFF indicator. If this light is going off then you may have a short somewhere within the receiver . Thats why if possible try a second receiver to see what results you get.
Regards.Comment
