Libertview m5 problem
  • tamgunner
    • 691
    Hi guys bought a brand new M5 box last week was on for 24 hrs and when I switch it on now it's got a dull 8 on the display and doesn't do anything else have contacted the seller but no reply yet anyone know if this is fixable?
  • hfxlad
    • Feb 2014
    • 91
    this might hlip you i no its f5s but you never no Originally Posted by kaisar1Hi, Got a problem with a skybox f5s satellite receiver. Have not come across this problem before. Basically on the front display it show "8" and also dim red light.
    Has anyone come across this problem before, and solution to fixing this problem.
    Any help much appreciated.
    Regards.
    Not got an F5s so going from what I've experienced in other Openb0x/Skybox.
    Dim lights on the display have previously been one of two issues. Either the [COLOR=#5939AA !important]Power Supply[/COLOR] Unit failing or firmware gone corrupt.
    First try booting the box with the Sat and Ethernet [COLOR=#5939AA !important]cables[/COLOR] disconnected. If nothing happens try anotherPower Supply if you have one. Last which I think may be the problem Use the [COLOR=#5939AA !important]recovery tool[/COLOR]. Same tool as for the F3 but
    • bubric
      Any luck
      Did u get sorted ? Any advice on wifi settings pls just got the box and cant for the life of me fint where to set up wifi ??
      Any help appreciated !
      Ricky
