skybox F3 no signal on all channels!!! HELP NEEDED
  • adal316
    • 6
    hi newbie here. ive got a skybox f3. it was working fine and about a week ago all the channels have gone off. even the freeview ones dont work.
    i have checked the settings and everything seems right. ive updated to the latest firmware and the channel lists but still nothing.
    i did however use the same CCcam.cfg file as my friend, i dont know if that is the problem. my box had expired and my friend just got a new box. i used the same CCcam.cfg and the box was working fine for about 2-3 months but now its not. do you think that is the problem.
    would appreciate some help, thanks adal316
  • hfxlad
    • Feb 2014
    • 91
    you you answered your own question pal that is the problem your ccam provider.
    • adal316
      • 6
      im thinking if it is the CCcam provider why did it work for 2-3 months. plus my friends box is still working. do you think it might be something else
      • hfxlad
        • Feb 2014
        • 91
        can not talk to much pal about it bcos of forum rules you was lucky you got that much time out of it.
        • adal316
          • 6
          but i have used that same CCcam on other skybox's and they are working fine. i dont understand why mine is not working. also is there anyway of getting the freeview channels to work
          • smok3y
            • Mar 2014
            • 5
            Doesn't make sense that FTA channels would show scrambled even if problem was external
            Does your box show a sat signal at all?
              • adal316
                • 6
                it shows a signal of between 7%-10%. i dont know if that helps.
                how would i got about to totally resetting the box to is factory settings
                • antomac
                  • Oct 2013
                  • 315
                  your problem seems to be either dish or connection from dish to box
                  take out cable coming from lnb and retry it again as its a signal
                  problem yo have
                  • adal316
                    • 6
                    yep i think your right antomac. i have tried my box at my friends house and its working fine, no problems so its definetly going to be the dish and or lnb. i will try what you have suggested
