no channels after update
  • hedhunter
    • Mar 2014
    • 20
    hi all, after del channel list (did save on usb) and install new all i get is no channel on box , no menu ,tv said no signal wtf help
  • fazz69
    • 160
    which date channel list have u updated. check your satellite cable is plugged in to box.
    latest AJ channel list is 26/4/2014
    • hedhunter
      • Mar 2014
      • 20
      26-4-14 checked everything......box say noch nothing at all no menu as above .....ho dear tryed on off etc nothing
      • sexysam
        • Oct 2008
        • 209
        You have to turn box off and then turn it back on once you have updated via USB
        • hedhunter
          • Mar 2014
          • 20
          yip , still nothing ...as said tv say no signal skybox say no channel , can get into menu on the box . dont get skybox logo when starting it up , the box says it loading then no chan ??? as if it isnt conected to the tv , but when i switch the sbox on it will the tv will flick to the hdmi 1 channel ........is there a reset button ? cant even get into the ffffffffkingggg menu to redownload the save to usb .........aghhhhhhhhhhhhh
          • sexysam
            • Oct 2008
            • 209
            was it working before this happened. You didn't update software on it prior to this happening
            • Hadron
              • 2102
              If your TV is showing a No Signal message, it sounds like the video format from the Skybox may be wrong. Perhaps someone pressed the V.Format button on the Skybox remote.
              Can you connect your Skybox up to your TV using scart or the composite video connectors? If so & you can get a picture, go to menu > system setup > TV system & change the video resolution until you get an output on the HDMI again.
              I use 1080i_50, but then my TV will work in any resolution, some others do not.
              • lee11168
                • Feb 2011
                • 217
                reload the channel list again you have not done it right
                • andy291024
                  it did the same to my mate what I did was a factory restore and make sure your DHCP is on in your network settings and all was working
                  • hedhunter
                    • Mar 2014
                    • 20
                    Hedron your a genious man ..followed your instructions with scart and changed HDMI to 1080 ....now it all works OK .....thanks man ...and to all ...saved me life again.....fellas. ..
