Hi there. I have recently flash burned Aj's list and when I look for info on the channels I get no info. Am I doing something wrong as I would like to be able to see what is on latter in the day on each channel and maybe use the epg to programme recordings.
Channel info
Taken from Sattv5 Channel List Stickie.
My Favourites are all wrong since I loaded your list how do i fix them ?
The way to get The favourites under the correct headings is to load the default Database:
On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct orderComment
That, my man, was the perfect answer and has solved the problem many thanksTaken from Sattv5 Channel List Stickie.
These boxes are a great piece of kit for ?50Comment
