Channel list category
  • mhairt
    • May 2014
    I have installed Aj's channel list and they are all there but are not grouped by category such as movies sports kids etc. How can I set the channels up by category? Also when a station is paused the audio continues. Any sokution for this?
    Cheers
  • mickzer
    • Nov 2013
    • 81
    From Sattv5s post:
    My Favourites are all wrong since I loaded your list how do i fix them ?
    The way to get The favourites under the correct headings is to load the default Database:
    On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
    The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order
    • mhairt
      • May 2014
      Originally posted by mickzer
      From Sattv5s post:
      cheers that did the trick
