Epg wrong
  • jstrevor
    • Oct 2012
    • 27
    Epg wrong
    Can anyone help?
    I've got an openbox v5s on latest firmware with aj's latest channel list. Got my line on etc all working but the epg seems to be wrong it's set to summertime so the clock is correct but the epg seems to be off by an hour or just not working at all
  • pgreenie1
    • Feb 2014
    • 41
    Have you got auto update on ? Sometimes you have to manually update check that first
    • jstrevor
      • Oct 2012
      • 27
      Yes auto update is set to on and I've done a fresh update on the epg also
      • hfxlad
        • Feb 2014
        • 91
        seems a bit weird that you are getting the 1 hour difference still as the latest firmware corrected that i would just check on your box that the latest firmware as correctly installed.
        • elpaulio101
          • May 2014
          • 18
          I had to play around with the Summertime/time offset settings...
          Mine is:
          GMT Offset: UTC + 00:00
          Summertime: ON
          Latest f/w, Skybox F5s
          3601HD_10_04_2014_0670 (this f/w fixed a lot of EPG issues)
          Auto update is ON, but it never seems to work properly because I switch my box off (standby)
          The EPG timings are now right
          • jstrevor
            • Oct 2012
            • 27
            Ok cheers guys will have a look when I get home and let you's all know. Appreciate the help
            • jstrevor
              • Oct 2012
              • 27
              Ok now it's all updated and correct, but on most channels it's just not showing any information at all.
              • elpaulio101
                • May 2014
                • 18
                Are you using the sat feed EPG, or the XMLTV one?
                Im using the XMLTV one, and its all good.. except where Im on the wrong transponder. Having said that, youre using AJ's channel list..
                Not much else to suggest im afraid mate
                Id be inclined to backup and start again, factory reset, full blind scan, reupload a NEWLY downloaded channel list etc..
                • jstrevor
                  • Oct 2012
                  • 27
                  Sorted now, I just re updated the epg this morning with summer time set to off then turned summer time on after.
