Picaso Plus HD box , what firmware update do i need ?
  • ollee123
    Hi All,
    Hope you can help me.
    i have a Picaso Plus HD box using 3601hd.abs but i've lost a few channels and if i try to update the firmware from USB it says 'Failed Download'
    although unsure which box firmware i should be using, is it Skybox F3 or F5 or something else ?
    Any pointers would be greatly appreciated.
    cheers
    ollee
  • Nobby Nutz
    • Apr 2012
    • 191
    Originally posted by ollee123
    Hi All,
    cheers
    ollee
    Not sure why you want to upgrade Firmware for Missing Channels.
    Is there an existing Channel List on the box ? What format .DBS ?
    If so can you not do a scan and manually add the missing channels to your existing list.
    What channels have you lost as there are quite a few HD channels that have disappeared.
    • mahrkpat
      • Jun 2012
      • 510
      Not heard of your box best just to do scan and make your own list up, putting in firmware or channel list when you not 100% sure which one to put in will end up with you having a expensive door stopper.
      • ollee123
        I had wondered as can't find out much about them.
        Thanks for the reply.
