F5s Case ?
  • tonynw
    • Nov 2011
    • 147
    F5s Case ?
    Hi
    Does any one know the best way to take the case apart on the F5 boxes looks as if the tuner has gone faulty and want to take it apart and see if I can get a replacement.
    cheers
    tonynw
  • Hadron
    • 2102
    I would be interested as well.
    The last time I tried it, I broke off most of the clips.
    • bigade1
      • Oct 2013
      • 340
      Your thread title states F5S but your post states F5. They are 2 different boxes. If it's any help I've taken a F5S apart. You need to remove the lid which contains lugs which engage into the sides of the box. The easiest way that I found to do this was by starting from the rear using a small thin screwdriver and placing it between the lid and the side and then gently prising the side so that the side bends outwards and releases the lug. Work your way around the box, bearing in mind that the corners have cylindrical pins which go into downward slots to keep it in place. Hope this is of help. I'll try to upload some pics later.
      • genam
        • Apr 2013
        • 176
        i wouldn't waste your time...not much in them that is replaceable .. tuner assembly is mounted direct to the pcb.
        I found a general table knife works quite nicely to open the case in the same manner as mentioned.
        • katieb
          • Feb 2014
          • 63
          i found a hammer works quite nicely on a skybox a good thud and your good to go
          • Hadron
            • 2102
            Originally posted by bigade1
            Your thread title states F5S but your post states F5. They are 2 different boxes...
            ...but the cases are exactly the same.
            • bigade1
              • Oct 2013
              • 340
              Nice one, that's something I didn't know.
