channel updates.
  • djmagic
    • Apr 2014
    • 8
    channel updates.
    as we know channels are going one by one only HD of course. so my question is when a channel update comes out can the HD channels that can no longer be received be removed from the channel list????
  • redralph
    • 171
    Yes they can
    • gilvey
      • Apr 2014
      • 113
      Yes, go to menu, channel edit
      Go to the channel you want to remove
      Ok to select then go to the right side panel and go down to delete
      Press exit and it will update
      Alternatively go to the sd channel you need to replace the hd one with, ok to select
      Go to right panel select move
      Then move into position to where the hd version was. Ok to unselect
      Then highlight the hd channel that needs deleting and delete as above
      Exit saves changes
      • djmagic
        • Apr 2014
        • 8
        thanks for the answers but can the channel list update not do all this for you... ??? or must it be done manually ??? maybe my question was not put correctly.
        • redralph
          • 171
          AJ has released a new channel list today and as the HD channels are removed he will replace them with the SD ones. It is case of waiting for updates if you do not want to do it yourself.
          • djmagic
            • Apr 2014
            • 8
            thanks i have the new list ... premier movies i have lost but its still on the channel list , this is what prompted me to ask the question.
            • joe516
              • 1000
              AJ's Skybox/Libertview List 21-5-14
              - Updates -
              Sky Sports News HD
              Box Office HD
              Sky Premier HD, Sky SciFi/Horror HD, Sky Disney HD have been replaced with the SD version.
              We'll lose the rest of the HD channels very soon.
              • djmagic
                • Apr 2014
                • 8
                Sky Premier HD is still showing on my system!!!
                • Hadron
                  • 2102
                  I've just installed AJ's latest list (25/5/14) & Sky Premier HD isn't on that one.
                  • joe516
                    • 1000
                    cheers m8 nice 1
