Skybox F5S Image with AJSAT Favourite names
  • Smurf786
    • Sep 2009
    • 195
    Hi,
    I have an image with Favourite 1, Favourite 2 etc. I have aj channel list loaded does anyone have an image for skybox F5S with ajsat favourite names. Or even if someone can make me a backup. Don't fancy inputting them in manually.
    Many Thanks
  • Steadysot
    • Nov 2013
    It's in the frequently asked questions in the 2nd post I think that's what the JPEG is for in the zip file
    • joe516
      • 1000
      Originally posted by Smurf786
      Hi,
      Many Thanks
      My Favourites are all wrong since I loaded your list how do i fix them ?
      The way to get The favourites under the correct headings is to load the default Database:
      On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
      The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order
