skybox f5s channel layout
  • dougm1970
    • Mar 2012
    • 103
    i am on the latest skybox firmware on a f5s.
    i'd like to have the old channel selection screen..
    at the moment i have this layout...
    [img=300x140]http://i.ebayimg.com/t/Skybox-F3-F5-M3-open-box-and-dream-box-Latest-firmware-and-channel-list-/00/s/MjMzWDUwMA==/z/LAEAAOxyuCJRfAdK/$T2eC16FHJHQFFhsTfuqQBRf!dKSD,Q~~60_35.JPG[/img]
    and i'd like to have it like this...
    [img=640x480]http://kameleon.ba/wp-content/uploads/2014/05/skybox-2.jpg[/img]
    is there a way i can do that ??
    can i do it without a firmware change??....and if i do need a firmware change, which firmware should i get ?
    thanks.
  • darcu5
    • Jun 2011
    • 944
    in the 2nd pic they have gone onto all sat channels and not the fav channels list like the 1st picture.
    • dougm1970
      • Mar 2012
      • 103
      no...its the same on all sat
      • darcu5
        • Jun 2011
        • 944
        it will be until u select a channel, then press ok or select.. whatever that big button is in middle of remote, i'll go dig mi old remote out and check and it will come up like the other pic
        • dougm1970
          • Mar 2012
          • 103
          thanks for your time / advice
          but when I press ok...big button in middle..the menu just disapears and that channel chosen is whats on.....maybe I misunderstand you.
          • martin035
            • Apr 2014
            • 1308
            On the F5S you have to change the GUI config;
            EPG then 'All' then select the first channel then 'exit' out of the EPG
            On the remote press 'M/P' then scroll to 'GUI Config' and change 'whole' to 'three' then press 'exit'
            Press 'OK' the center round button and you should get the view you want
            • darcu5
              • Jun 2011
              • 944
              ayyy it doesnt does it, just dug openbox f5s out cupboard n tried it, on the older boxes it use to open up as i say but on the newer ones it opens the one colum up and if you press right it goes onto epg. stoopid idea that.. sorry mate, cant help you there im afraid, i think you can flash the f5s with the f5 firmware but not the other way round.. dont take my word for that though; wait and see if someone has tried and tested it post here to confirm it does work.
              • darcu5
                • Jun 2011
                • 944
                Well done martin.. just followed them instructions and it changed it, didnt know you could do that. cheers fella.
                • dougm1970
                  • Mar 2012
                  • 103
                  that worked.
                  thank you.....appreciate your time to reply.
