hi all i was watching tv on my f5s then it frozen and would not turn over so after 15 min i powered down and when i turned it back on i got a dim red light and a dim number 8 i have changed the plugs and it is still doing it can anybody please help
Heard rumours you could flash with rs232 cable and will come alive for some, mine I played with it for 2 weeks came at a stage I binned it not woth spending time they cost pienuts.
Try a reflash but use this file SB.abs dated 10/05/2013 and no bootloader.Also not advisible to use usb via laptop, better to use desktop with compatible com port for null cable.
Regards.
Reaper.
