Skybox f3 settings
  • Champ03
    • Jun 2014
    • 7
    Skybox f3 settings
    Hello All.
    i am new to this forum and looking for help from all who can help. I need help with my skybox settings. My lovely daughter has reset all the settings and I have lost the information to get everything working again.
    i would appreciate any help on this especially the tp list, antenna set etc to get the box working again.
  • martin035
    • Apr 2014
    • 1308
    • Champ03
      • Jun 2014
      • 7
      Thank you for the help guide. I actually need the installation set up details, all my tp list is blank and also my antenna setup up looks incorrect. It appears everything got wiped.
      • martin035
        • Apr 2014
        • 1308
        Try installing either the latestAJ's or sattv5's channel list, found in the red stickies.
        • Hadron
          • 2102
          Try installing a channel list again. Either AJ's or sattv5's.
          This will put all the TP's back again.
          The antenna setup should show Satellite = Sky UK 28A. LNB Freq = Universal (9750-10600). DiSEqC 1.0 & 1.1 = Disable. Motor type = Off.
          Transponder will show the current one corresponding to the channel selected.
          EDIT...great minds think alike eh martin035.
          • Champ03
            • Jun 2014
            • 7
            where can I find the image file....(abs)
            • martin035
              • Apr 2014
              • 1308
              AJ's
              Sattv5's
              Your choice
              • Champ03
                • Jun 2014
                • 7
                mine satelittle list says SKY-UK, 0.282E, universal(9750-10600), disable,disable.... off.
                • Champ03
                  • Jun 2014
                  • 7
                  can only see channel list, unless I'm being stupid.... sorry for all the questions.....what would the image file be called?
                  • martin035
                    • Apr 2014
                    • 1308
                    And so does mine
                    • Hadron
                      • 2102
                      A channel list is what you should try first. It may get your channels back.
                      Firmware for genuine boxes is on the skybox.cc website, but don't try that yet.
                      • Champ03
                        • Jun 2014
                        • 7
                        should it say hardware mismatch when I am trying to install.....??
                        • martin035
                          • Apr 2014
                          • 1308
                          In AJ's link, you will see in the last post a blue file 'AJ's list 20-6-14.zip' download it, then unzip, then install the .dB's file
                          • martin035
                            • Apr 2014
                            • 1308
                            Is this for a channel list update from this forum or a file from skybox.cc
                            • Hadron
                              • 2102
                              Follow AJ's instructions here for installing a channel list:-
