F5s ping question
  • gazzaull22
    • 191
    F5s ping question
    Hi all
    Ive been having this problem for a little while and i have decided to get to the bottom of whats going on!
    ive got aj latest update along with the new firmware for the f5 box .
    all channels work as they should
    but im getting alot of scrambling glitching etc
    i know that this could be down to alot of other issues but having narrowed it down to either my internet connection or a router issue or even an issue with the input to my f5 box then im looking for a little help
    my setup is as follows
    zyxel amg1302-t10b router
    hardwired connection from this router to f5 box(new cables etc )
    in my network options on the f5 DHCP is on and the ip is showing 192.168.001.036
    i used my laptop to ping this ip address?(laptop on same network as the sky f5)
    if i ping 192.168.001.036 i get a different response to pinging 192.168.1.36 (without the zeros added)
    question is which one do i ping???
    the only one i can get anything off is the 192.168.1.36
    i have pinged this 3 times and got the following
    ping 192.168.1.36
    Pinging 192.168.1.36 with 32 bytes of data:
    Reply from 192.168.1.36: bytes=32 time=6ms TTL=255
    Reply from 192.168.1.36: bytes=32 time=2ms TTL=255
    Ping statistics for 192.168.1.36:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss
    Approximate round trip times in milli-seconds:
    Minimum = 2ms, Maximum = 6ms, Average = 3ms
    ping 192.168.1.36
    Reply from 192.168.1.36: bytes=32 time=26ms TTL=255
    Reply from 192.168.1.36: bytes=32 time=13ms TTL=255
    Reply from 192.168.1.36: bytes=32 time=9ms TTL=255
    Minimum = 6ms, Maximum = 26ms, Average = 13ms
    is this good or bad ????????
    any advice would be good
  • martin035
    • Apr 2014
    • 1308
    The ping test your doing is only testing your home network not the internet ie laptop - router - f5s
    you need to ping an external address to find out your ping speed, use Google and even better your providers address.
    Here's my ping results for you to compare;
    C:\Windows\system32>ping ##.##.##
    Pinging ##.##.## [provider] with 32 bytes of data:
    Reply from provider: bytes=32 time=48ms TTL=56
    Reply from provider: bytes=32 time=50ms TTL=56
    Reply from provider: bytes=32 time=49ms TTL=56
    Ping statistics for provider:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Minimum = 48ms, Maximum = 50ms, Average = 49ms
    C:\Windows\system32>ping Google
    Pinging Google [62.24.154.222] with 32 bytes of data:
    Reply from 62.24.154.222: bytes=32 time=34ms TTL=61
    Reply from 62.24.154.222: bytes=32 time=88ms TTL=61
    Reply from 62.24.154.222: bytes=32 time=31ms TTL=61
    Reply from 62.24.154.222: bytes=32 time=56ms TTL=61
    Ping statistics for 62.24.154.222:
    Minimum = 31ms, Maximum = 88ms, Average = 52ms
    As you can see my returns are quicker from my provider than from google
    • gazzaull22
      • 191
      thanks for the reply martin
      i have pinged his zapto address see below for results (ive **** the main info to keep within the rules)
      *************.zapto.org
      Pinging ***************] with 32 bytes of data:
      Reply from 88.150.143.194: bytes=32 time=48ms TTL=58
      Ping statistics for ***********:
      Minimum = 48ms, Maximum = 48ms, Average = 48ms
      ***********zapto.org
      Reply from 88.150.143.194: bytes=32 time=122ms TTL=58
      Reply from 88.150.143.194: bytes=32 time=246ms TTL=58
      Ping statistics *****************
      Minimum = 48ms, Maximum = 246ms, Average = 116ms
      Pinging *****************] with 32 bytes of data:
      Ping statistics ***************:
      C
      Reply from 88.150.143.194: bytes=32 time=157ms TTL=58
      Minimum = 48ms, Maximum = 157ms, Average = 75ms
      • martin035
        • Apr 2014
        • 1308
        You've got 3 different results, can you turn off your f5s and anything else that uses the internet and ping Google (need www. address as forum shortens it) and post results.
        • gazzaull22
          • 191
          so ive unplugged everything from the router and turned off anything wifi apart from this laptop im using now
          results from Google(i pinged x3 times )
          Microsoft Windows [Version 6.3.9600]
          (c) 2013 Microsoft Corporation. All rights reserved.
          C:\Users\martb>ping Google
          Pinging Google [173.194.41.79] with 32 bytes of data:
          Reply from 173.194.41.79: bytes=32 time=95ms TTL=57
          Reply from 173.194.41.79: bytes=32 time=41ms TTL=57
          Ping statistics for 173.194.41.79:
          Minimum = 41ms, Maximum = 95ms, Average = 54ms
          Reply from 173.194.41.79: bytes=32 time=70ms TTL=57
          Reply from 173.194.41.79: bytes=32 time=87ms TTL=57
          Reply from 173.194.41.79: bytes=32 time=105ms TTL=57
          Minimum = 41ms, Maximum = 105ms, Average = 75ms
          Reply from 173.194.41.79: bytes=32 time=42ms TTL=57
          Minimum = 41ms, Maximum = 42ms, Average = 41ms
          • martin035
            • Apr 2014
            • 1308
            You ping results seem ok both Google and provider, however, my only concern is 2 of your providers results are poor (Max 157 & 246). This won't cause glitches at present but if your provider is heavily loaded and at peaks ie footy match on, this could overload and cause glitches
