Possible faulty tuner? Help please
  • Hadron
    • Nov 2012
    • 2102
    #16
    The no signal fix is normally only for problems with vertical channels, not horizontal. And usually when you have another box connected to the same LNB.
    • chuckles53
      • 320
      #17
      If in doubt just change the lnb and bobs your uncle.
      • ronangally
        • Jul 2013
        #18
        I have exact same issue. Problem is with H channels and not V. Goin to try no signal fix first before Lnb replacement as my original box works fine off same lnb
        • jay876
          • May 2014
          • 14
          #19
          [QUOTE=ronangally;2338454]I have exact same issue. Problem is with H channels and not V. Goin to try no signal fix first before Lnb replacement as my original box works fine off same lnb
          Has the no signal fix worked for you?
          • ronangally
            • Jul 2013
            #20
            While waiting for my no signal fix cable my skybox stopped powering up. No display atall. Got a similar box, open box v5s. Arrived same day as no signal fix cable. Hooked up new box wit no signal fix cable. All working fine now. So I'm not sure if it was the new box or the fix I cable that fixed my issue, all I can say is it wasn't my lnb or my signal from the dish
            • mikecarey
              • Dec 2010
              • 85
              #21
              this could be a similar problem that im having with skybox f5s, bbc is fine and around 75% signal, now if i go to sky sports 1 sd, its around 60% but drops to 5% and breaks up, freeview chans seem fine but paid ones not, now ive not really had any strong winds but the dish is old, so could be the lnb on way out? ive got a new quad lnb here but how easy is it to put on the dish and try it, making sure its all aligned
