EPG LIST ONE HOUR BEHIND
  • spanner73
    • Feb 2014
    I have installed the EPG settings on my skybox f5s it is fine apart from the program event is saying it starts at 22.00 when in fact it starts at 21.00 , one hour earlier how can i fix this cheers
  • royalsat
    • Apr 2014
    • 16
    • spanner73
      • Feb 2014
      do i set the file to misc file or image file and will it effect my cline or Ajs list, and do i upgrade by usb or dump thank you
      • darcu5
        • Jun 2011
        • 944
        if u choose to keep settings it should keep ur line and channel list, and yes it is an image file,
        also if u are worried u can go to dump to usb and select the bit u want to save.. plug it into pc and open the file with notepad to make sure it is all in order b4 u start
        • royalsat
          • Apr 2014
          • 16
          Unzip to usb
          Load file SKYBOX_F3S_F5S_3601HD_CMT_14041006DA.abs
          Make sure
          System Setup -->EPG Default Setting ,and Set Summer Time "ON" to correct the time
          Keep DBS & Settings Yes
          You won't lose any settings it just corrects the time issue.
          • colin1939
            • May 2014
            Thanks - that worked for me. Kept all settings and fixed the 1 hour time-shift.
            • spanner73
              • Feb 2014
              yes worked a treat
