Hello!
I came to this forum looking for help and thanks to a few comments in a forum on here I was able to find a work around for all USB serial cables.
A few people have said that USB to Serials are very hit and miss, that is because you've bought the wrong type that is wired differently, plus they are meant to use plugnplay to assume which pins you want to use by gathering feedback from the device your plugging it in (this doesn't work)
My problem was I bought a USB to SERIAL thinking they were all the same and they are NOT!!
Slugworth stated that the OPENBOX used only 3 pins and using his key I was able to wire the correct pins together.
The key is:
Serial
Skybox/Openbox
2-3
3-2
5-5
Here are some images that should help!
My First Problem: MALE + MALE
Solution: FEMALE + FEMALE from amazon ?1.20
Now, I knew that I needed 3 wires in 3 holes on one side of the female to female.
I put wires in: 2,3,5 & hot glued them.
Now I connected the adapter to the splitter & then the wires to back of the box.
I connected the wires as in the key ABOVE
2 to 3 etc..
The wires I used were just ones I collected from old computer motherboard press connectors, you can bend the pins and pull them out so they will slide over the pins in the back of the BOX.
I know this isn't exactly a professional tutorial but hope I help everyone who is struggling!
Regards.
The key is:
Serial
Skybox/Openbox
2-3
3-2
5-5
2 to 3 etc..
Regards.
