Hi, I'm trying to update my channel list. I have downloaded it from aj Sat with WinZip but when I try updating it says no files found. Any help please Michael
updateing
Tags: None
When you say that you downloaded it from AJ sat, do you mean AJ's own website? If so, then it doesn't need to be unpacked. It is ready to use.
If you downloaded it from Digital-Kaos, then after unpacking, it should have a file name of TP_PROG.dbs with a file size of 1024kB. If it doesn't have this file name, then it won't be recognised. -
Got it sorted. It was because I had downloaded it more than once and the file name was numbered. Thanks for the reply.Comment
