confused
  • lostjob
    • Jan 2014
    • 6
    confused
    Some of my channels just say scrambled, i have the latest firmware and latest channel list, i did a blind scan and found alternatives to some channels but not all. Can anyone advise please?
  • martin035
    • Apr 2014
    • 1308
    You do understand that other things are required before the channels are unscrambled. If you have the required files installed, then best advice I can give within the forum rules is to ensure your box is connected to the internet. If the internet is working on your box then contact your provider for assistance.
    • lostjob
      • Jan 2014
      • 6
      we have been using the box a while now, all of a sudden a handfull of channels just say scrambled. Ive asked my provider but when he checks he gets everything perfect so is just as stumped as me
      • martin035
        • Apr 2014
        • 1308
        Could be an internet problem, check to see if your box is connect ie see if YouTube works
        If that's OK it could be a LNB voltage problem, long shot but might be worth a try, as they only cost about ?4, search ebay for a 'no signal fix'
        • hardy1812
          • Jul 2014
          • 16
          Mine sometimes does it. I just unplug the box for 30secs and let it reboot again, that seems to sort it out.
          Had it last channel update couldn't get a movie channel but turning off and on helped.
          • The Reaper
            • 73
            Sometimes a high wind and rain will move a dish/lnb just enough to fracture reception so it's worth a check.
            A reboot often helps.
            A reboot of the i-net also helps as modem has a mind of its own.
            Reaper
            "Everything I do is legal---I think."
