Skybox F3 Stuck on load
  • Jayob10
    • Oct 2013
    • 38
    Hi there,
    For the last while I have been unable to use my Skyboxf3 as it has been stuck on load. I encountered problems after updating my channel list (AJ's channel list) which I had done successfully on numerous occasions.
    The box is basically stuck on load and I have now plugged it out. I cannot even revert to the channels I had previously.
    Can anyone advise what to do next? Bear in mind that i'm not the most tech savvy, I've looked at numerous other threads etc... but its like reading a foreign language sometimes and i'm not sure if the content is applicable to me.
    Any advice would be greatly appreciated.
    Thank you
  • BrunoJ
    • Jul 2013
    • 141
    Hi, you need to flash your box .
    Try this Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable or try this one on bay SkyBox F3 F3S F4 F5 F5S Repair Service Fix - Brick - Flashing - Stuck on Load ?
