Signal
This topic is closed.
  • wroenaldinho
    • Aug 2012
    • 56
    Signal
    Hi All
    Got skybox f5s and a skybox f3 in seperate rooms. Both have brilliant signal over nost channels however the ones i cant get and i get around 5-7% is all skysports (apart from sky sports news which works) it was all working fine a few months ago but the ss1-ss5 and ssf1 are no longer working. Ive tried removing a box from the lnb to see if it improves with just the f3 on and it doesnt. Any suggestions?
  • mikecarey
    • Dec 2010
    • 85
    im having some similar problem at the moment, got bbc1 at mo and signal is 77%, if i goto any sky sports its starting around 70% and then goes to 5/7% and picture breaking up and then no signal, are we all having a lnb problem or is sky got sum crazy thing going on
    • jay876
      • May 2014
      • 14
      I'm getting a signal issue too. The problem I've got is that all my vertical channels are working fine but it's the horizontal channels that are showing the no signal sign?
      Anyone know why this is and how it can be fixed?
      • mikecarey
        • Dec 2010
        • 85
        ill prob get banned or a warning for it but... ive just been give a test gift, and the signal has remained solid, could it be down to our suppliers?
          Yes mate it will be.. best edit your post now
          • earney
            • Apr 2014
            • 14
            having same issue, anyone any recommendations? Ihad a problem a while back with a faulty LNB not getting horizontal signal maybe this is the issue again?
            • digicon
              • 8261
              Guy's can i just remind you this sort of discussion aka 'Gifts' 'Supplier' 'Server' etc.. is a no go area on DK you can of course find everything out you need via a simple google search
              Thank you
