my openbox v5s kepps saying invalid programme search again . the thing is if i turn it of the channels come back on and then after a while the same problen occurs any help please
Invalid programme search again
Tags: None
If it's a new box and has did it from the start you probably need the "no signal fix" available via ebay, if you've had the box a while and it's just started happening I would check all your cabling back to the LNB or maybe try a reflash (be careful you have the right firmware for your box). If none of that works it may indicate a more serious problem such as a power supply failing. -
