Av to rf out
  • pauljones83
    • Sep 2012
    • 4
    Av to rf out
    Is this possible on my f5s . I want to distribute the tv
    around the house any help appreciated
  • dufmyster
    • Sep 2009
    • 42
    Yes. Get a hdmi splitter and split the signal to 2 or 3 rooms. Only prob is you need to all watch what's on the box
      You require an RF Modulator rough price from a popular auction site is around ?16-?18
      • pauljones83
        • Sep 2012
        • 4
        Will a rf modulator work with modern tvs ? i thought it was the old style tbs for this
        • pauljones83
          • Sep 2012
          • 4
          Ive got a modulator can't get it fired up ? rf in to the back of it av from modulator to f5 then hdmi to the tv ?? am i doing it wrong
          • andybhoy67
            • Jul 2012
            • 10
            Can you use a magic eye with this?
            • pauljones83
              • Sep 2012
              • 4
              not sure about magic eye anyone got any info ?
                as long as your Plasma/LED/LCD etc... has an inbuilt A.n.a.logue tuner then you can use an RF modulator, Most come with Scart connection so that you can feed RGB from the Scart on the F% directly into the Modulator and then feed that into your distribution system.
                If you want Magic eye capability then look at the Triax Tri-Link:
                http://www.triax.co.uk/upload/tri-link_aug_2010.pdf
                costs around ?40
                Your last Option if money is no object is to install a Pro-DVB-T Modulator which will give you a freeview frequency on any Freeview equipped TV so no need to worry about the A.n.a.logue side, Of course these are expensive and start at around ?400 for a basic one rising to around ?1800 for a HD version.
                I think most would probably opt for the ?18 -?40 range personally
