FIRMWARE UPDATE
  • hamster1978
    • Jul 2013
    • 27
    FIRMWARE UPDATE
    Hello
    After a bit of help. Trying to reset my firmware on my SKYBOX F3 as done channel update list and now stuck on load.
    I have downloaded the skybox upgrade tool and the .abs file.
    I turn off the skybox
    plug in the rs232 cable and plug it in to my laptop (via USB)
    load up the application from the download tool. Cange the port to COM3, if i use another port i get serial port is failed try again.
    tick the bootloader box and press next
    now it says at the top of the box synchronizing STBs done please reset target. and at the bottom it says "set stb memory error, click back to try again"
    Any ideas what Im doing wrong of it the box is proper dead
  • shawy1970
    • Nov 2013
    • 98
    cant do reset via rs232 with usb....EVA!!!
    you need data connectors at both ends
    it will keep saying mem error untill u use rs232
    if laptop doesnt have rs232 data socket then try an old pc they have them
    it will then work in 30 seconds definatley
    • hamster1978
      • Jul 2013
      • 27
      Thats what i have thought. Will try and get the part and stick it in a PC
      thanks for your help
      • stealth666
        • Dec 2011
        • 22
        As a rule unless you box absolutely requires a firmware update, don't bother!
