Bricked S11
  • birch39
    • 34
    Bricked S11
    i have a S11 box look to be bricked. There no power light on front seen etc. I ran the EromUpgrade and it says synchronising STBs please reset target as soon as i turn the switch on i get initiate STB sdram is failed. I used a RS232 usb cable.
    Any help or suggestion am i doing something wrong or has the box ran its last legs
  • slugworth
    • Nov 2011
    • 1064
    use loader v2.0.0c and when you hit next on the loader is when you turn the receiver on.
    If it still doesn't work it's probably the cable.The loader was designed to work with a pc and real com port.
      Power board is gone m8 i had the same issue new board then box as good as new.
      • birch39
        • 34
        if the power board is gone is it easy to fit or is it better off buying a new box.
        • Hadron
          • Nov 2012
          • 2102
          Are the lights on the ethernet port on the box lit?
          If so, it probably means that the main board is getting power. The fact that the loader program recognises that the box is being switched on (even though it throws up an error), also indicates that it's getting power.
          You could still take a look at the power supply board. Check that capacitors C11 (1000uF 10v) & C15 (470uF 10v) are not bulging. The tops should be perfectly flat.
          Unplug from the mains first, before removing the cover.
          • vorlon2257
            • Sep 2011
            • 356
            If you confident enough with a soldering iron fix it yourself, will work out cheaper for you. Like Hadron has stated will be either 1 or both of the capacitors, just search on Ebay for them using the info he has provided. The panasonic capcitors are the best buy but a bit more expensive than the other ones there but I have found that the slightly cheaper ones work just as good.
            Think I've fixed about 6 s11 boards now and equal amount of skybox F3 boards(they use same capcitors) as well and so far have had no returns. The openbox X3 uses totally different cap's.
            Just make sure you don't lift the soldering track off the board when you remove the bad one.
