f5s box
  • abbo666
    • Aug 2014
    • 13
    f5s box
    hi can any1 help..im tryin 2 connect a hd 2 my f5s box its in fat32 but the box wont use it....any help
  • martin035
    • Apr 2014
    • 1308
    What do you mean be 'box won't use it?'
    The F5s might not like the HD or USB adaptor, try another HD or USB stick drive and see if that works.
    • abbo666
      • Aug 2014
      • 13
      hi pal..wen i plug the hd in the box wont recognize it,,it just says no storage divice
      • martin035
        • Apr 2014
        • 1308
        Can you try another HD or USB stick drive?
        • abbo666
          • Aug 2014
          • 13
          my usb stick works...not got another hd but thats works on pc/tv
          • martin035
            • Apr 2014
            • 1308
            As your USB stick works it does sound like a compatibility issue, therefore unfixable
            I hope I don't offend you with this question but the HD is powered by the USB port you don't need to plug in an external power cable?
            • abbo666
              • Aug 2014
              • 13
              no its powered by usb port
              • Hadron
                • 2102
                Are you using a USB lead with 2 plugs on the end?
                I made the mistake once of plugging in the thinner lead, which is only for power & doesn't have the data lines connected.
                You're not making the same mistake as I did are you?
                • abbo666
                  • Aug 2014
                  • 13
                  no just 1 plug in hd and 1 plug in box
                  • shawy1970
                    • Nov 2013
                    • 98
                    are lights flashing on hdd??
                    • abbo666
                      • Aug 2014
                      • 13
                      carnt remember if it flashers or just stays on but def lights up
