I've finally sussed a good way to sort out the TV channel list in alphabetical order
by going into the channel edit cascading menu via the main menu button the picture
of the TV then select channel edit then in said menu press the small red button on
the remote scroll down to the A - Z option then press okay another small cascading
menu will appear with a list from A - Z use the Up/Down left hand side of the remote
to scroll through each single individual letter so for example when one selects the
letter 'A' a list of all the channels beginning with the letter 'A' will appear in black
once said list has appeared press the little green button on the remote which will
bring up another small cascading menu entitled 'Options' in this small menu press
okay on the option 'Select All' then press okay then press the little green button
again & scroll down too the option 'Lock' then press okay then press the little
red button again & scroll down down to the A - Z list & repeat the same procedure
under the letter 'B' & then so on to the end ('Z') said letter appear in said small
cascading menu in a group of letters use the said up & down arrows to scroll
through the groups of letters once one has gone through said procedure from
start to finish & comes out of said sorting said channels into alphabetical order
& then brings up the 'All Channels List' by pressing okay via the little green
button again one will see the option of the 'A - Z List' select this option which
should move all the channels into an A - Z List then by pressing the little
Green button again & scrolling down to 'Lock' & repeating this manoeuvre
a couple of times in other words if it does not work the first time it should
the second time point being it will lock ones TV Channels list into a alphabetical
A - Z List
I've tried AJ's Channels List before which tends to sort out all the Sly UK
TV Channels list in order & deletes all the others channels on ones list
which can be a bit annoying for example if one wants to keep the Irish
TV Channels it's looks pretty & well organized but one losses some channels
which they might of wanted to keep however one has the option of going
back into the TV Channels choice in the Main Menu & Deleting All Channels
then go into the Installation choice in same Main Menu the select Single
Satellite Search & It will bring back all the TV Channels that one had
previously on ones set list however one will have to go through the exact
same procedure which I've explained above to keep the said set list in a
Alphabetical order
There is also a procedure of sorting ones TV Channels into a Favourites
List for example 'Sport/Movies/Music/Lifestyle/Etc-Etc if anyone has
suggestions on how to do this manoeuvre then by all means let us know
because it's another quick way to access ones choice of viewing instead
of having to scroll through 'The All Channels List' we're all ears
Later's Folks. :-) :-) :-) BJTT
A - Z List
Alphabetical order
