Hi guys have came down the stairs to find the message mode not supported on my telly.Tried powering off my skybox and telly with no luck anyone got any ideas?
skybox F5 mode not supported
Tags: None
As goldberg says, it looks like someone has pressed the V format button on the remote. If you have trouble getting you picture back by pressing the v format button again (I think there are around 12 video resolutions), then you can try connecting by scart or composite leads. You can then go to menu > TV system & change video resolution to 1080i_50 (or whatever your TV likes).Comment
Thanks guys it was the Vformat button I had to press it quite a few times before it displayed. Note to self dont leave the controls lying around for your wee boy to mess about with.
F.T.O.FComment
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
There are 5 main choices with the V FORMAT button
480P/576I (interlaced). (This is good for scart connection).
720P is for older style Plasma and the odd late CRT (Cathode ray tube), usually with a D sub connection or component connections.
Pal amnd RGB are for the UK tv,s 50Khz.
1080I and 1080P (Progressive) are for HDMI connections ( gold plated connections are a wast of money as you are sending a digital signal and there is Forward error correction for any bits it has misseds and will buffer the signal.
Hope this helps.
Warning you can block the picture form a HDMI or SCART tv so be careful what you change.
The V Format button will get you out most of the time, but not always.Last edited by reddishd; 12 September, 2014, 23:55.get on your or off your box, with a bong!
At least once a month,
You only live once!Comment
