FTP to skybox f5s
  • Colin070179
    • Aug 2014
    • 6
    FTP to skybox f5s
    My Box crashes when I connect the LNB cable I have been told it is because the .cw and .cfg files are corrupt and I need to delete them and replace them with new using FTP.
    Can someone please help on how to do this.
  • Nobby Nutz
    • Apr 2012
    • 191
    I'd check your Coax Cable connections first before starting to replace firmware etc.
    A corroded or short circuit connection will cause the same symptons as you are describing.
    HTH
    • plasterer
      • 1631
      Dident know you could F.T.P to a F5 mate ....................Paul
      If your Happy with the Help push the Thanx button
      PAUL
      • Hadron
        • 2102
        You cannot use FTP programs like filezilla etc. but there is a program called LAN Tool that lets you transfer certain files to & from the box.
        colin070179...have a look at this thread (from post #65):-
        ...but as Nobby Nutz says, check out your LNB cable first. Although a short circuit in the cable normally causes the box to restart, rather than crash. It may be worth taking off the F plug, cutting back the coax, redoing the end & refitting the plug.
        • genam
          • Apr 2013
          • 176
          FTP lan tool CAN brick an F5 / F5s...its pot luck though....i was doing it for months then 1 day....ooops bricked...never got it fully sorted.
