1 dish 2 boxes via a splitter
  • DLINKLA
    • 128
    Is it possible to run 2 boxes off 1 cable via a 2 way Splitter for split TV signal from aerial + 3 F connector
    I've seen this Item Number: - 181507680642
    What would happen I did
  • cactikid
    • 12017
    no all satboxes need their own feed from lnb on sat dish.you can get connectors [ name unknown ] to allow aerial feed on house roof to combine sat feed to run through one cable and the same connector at other end to split signal back to sat and aerial.
    • Hadron
      • 2102
      If you use that splitter, you will only be able to have 1 box on a time.
      If you tried using both boxes at once, then you would not be able to view a lot of channels, as each box sends signals to the LNB that control horizontal/vertical polarisation & hi band/low band switching.
      • R0BINH00D
        • Sep 2014
        • 5
        you would need to get a new "LNB" with more connector points off your dish easiest way bud but as the others have said you would only be able to use 1 box at a time as the signal would be all over the shop and too weak as each box needs its own direct feed at all times
        • DLINKLA
          • 128
          Ok thanks
          If i used this and used 1 box at a time would it work fine ?
          • cactikid
            • 12017
            and if something blows up? remember satbox sends power to lnb,take chances kak happens,do it right and be happy.
            • Hadron
              • 2102
              Ok thanks
              It should work OK, as long as you turn off 1 box before turning on the other box...just to be on the safe side.
              Also the splitter you linked to, doesn't say that there is a DC passthrough on either of the outputs. You need the DC passthrough to control the LNB.
              This one looks more suitable (although it doesn't have the F plugs with it):-
              F-Type Screw Connector Splitter For Virgin Cable Sky Satellite 2 way | eBay
              ...or you can get them in pound shops.
              • ronsky123
                • Jul 2011
                • 32
                youse the loop then no need for splitter but still youse one box at a time
                • DLINKLA
                  • 128
                  How do I use the loop
                  • DLINKLA
                    • 128
                    My 2 boxes are on the same tv so 1 will be on standby and maybe recording while I use the other
                    Do I set it up like this
                    2 wires coming in the house
                    1 goes to f5 box
                    1 goes into recording box
                    Loop wire from f5box into other box
                    • cactikid
                      • 12017
                      that means 2 boxes working at once as you need a feed to view and a feed to record and as i said before get another feed in.
                      • DLINKLA
                        • 128
                        It will have 2 feeds
                        1 for recording
                        1 for which ever box I'm watching - with the recording box connected via the loop output (and of course the original recording input
                        • mtv1
                          The Stig PT
                          • 4413
                          you need a separate feed for each box if its a dual tuner ie record able box you need two feeds you can not split or loop sat feed you need one for each or two for recording
                          • Hadron
                            • 2102
                            1 goes to f5 box
                            From your original post, I assumed you had 2 skyboxes/Openboxes that you wanted to run from 1 feed.
                            When you say "the recording box", do you mean a $ly+ box?
                            As mentioned above, you cannot run both boxes at the same time using the splitter or loop. If it is a $ly+ box that you have, then whether it's in standby or recording, the LNB circuits are still active, so will interfere with the skybox/openbox.
                            You could put the $ly+ box in single feed mode & do away with the Dish2 input altogether, but you would only be able to record the channel you are tuned to.
                            • ronsky123
                              • Jul 2011
                              • 32
                              yes you can recording box ie s/y box loop to another box f5 and another box cannot be used together on the same lnb port
