Skybox f3 won't work in neighbors house!
This topic is closed.
  • red1
    • 41
    Hello everybody I'm at my wits end!
    I have a skybox f3 that works without any problem in my own house and I have eircom bb, but when I take it to my neighbor's house it won't work and he has upc bb, I have done all the usual with firewall and all that,any help would greatly appreciated?
    thank you.
    Red1
    Do the usual, switch off the rooter and box, switch on rooter when up and running you switch the box at the end that way the ip address will connect.
    • red1
      • 41
      Thanks but I have tried that, any other ideas?
      • jstrevor
        • Oct 2012
        • 27
        Check fta channels, if your not getting fta then their dish is not aligned properly
        • ash08
          • 20
          are you using a dns?
          if not check that your neighbours box is looking for the right ip and not a local ip like 192.168.1.10
          dont want to say much more regarding servers n clients due to forum rules
          • pappafoz
            • Jul 2013
            • 18
            DHCP issue maybe ? Go into menu - select Network - Network Setup' and turn DHCP 'off' if its on and vice versa if its off by using arrow keys and then hitting apply.
            • red1
              • 41
              FTA all ok.
              • red1
                • 41
                I think you might be on the right track, could private message me please what to do?
                Sorry this message is for ash08.
                • normboro
                  • Apr 2010
                  • 30
                  I have got a similar box tried changing ip address but still wont connect to the server
                  • noelo
                    • Aug 2014
                    • 10
                    had similar problem. it was the router, just wouldnt see box.try a different router in Friends house. good luck
                    • P&D
                      • 2686
                      thank you.
                      Red1
                      Follow pappafoz info DHCP issue maybe...... turn off reboot the box.......once the box restarts......turn on ......then reboot the box....this clears the old IP address on the box
                      • mickmc68
                        • Sep 2009
                        • 96
                        Are you trying to use the same line at 2 different addresses ?
                        Mick
                          Closed! due to the last comment and where this is heading read the Rules: http://www.digital-kaos.co.uk/forums...rules-2/#post2
                          • Linking to Card Sharing Payservers for any reason is not allowed
                          • Discussions about Cardsharing are not allowed, including, but not limited to, CCcam, Oscam, MGcamd, Gbox, Mbox, etc....
                          • Discussions about Servers, Clines, Gift's etc will be edited or removed.
                          • No asking for lines.
