skybox f5s problem
  • satphil
    • Oct 2014
    skybox f5s problem
    Hi all
    Had a f5s box with gift for a few months but more and more channels are scrambling, tried router and box re start but no joy. The seller has now disappeared but hopefully lesson learned. Now my question is is the box any good ie can I factory reset and start again, I have managed to open the lock pin code and all menus can be opened except the 3 usb settings. As I have said can box be worked with or just buy another box. Sorry if question already posted.
  • sexysam
    • Oct 2008
    • 209
    See Pm I sent you mate
    • BrunoJ
      • Jul 2013
      • 141
      Hi, 1st the box is working by nothing wrong with it. About the 3 USB Setting you can open because you need to connect a USB to the box them they will become active. About the "REST" sorry but we can't talk about due to the forum rules. You need to get a new "Milk Man" to deliver it to you
      • da21384
        • Dec 2014
        • 4
        hi got problem with my f5 box gift is on there and working as it is used on another box but cant get the channels on normal channels working but no gifted channels please can someone help pm me if possible most appreciated
        • P&D
          • 2686
          You cannot use it on 2 boxes at the same time....unless you have permission to do so .....
          to gain access to $ channels ONLY Google will help you.
          As you say you can get FTA channels so the box is working.
          • princecarroll
            • Jan 2013
            • 60
            didnt see last post
            Check Menu,Network Settings,if connected by Ethernet, make sure green light is on above Ethernet icon,if it is on green, press set up. DHCP should be turned to "on". If on the "off" setting switch it to "on" and press apply.This may be the problem.Let me know.
