Sound but no picture Skybox F5S even with latest firmware.
  • blacky1973
    • 304
    Hi I have the latest firmware (11/04/14) installed on my Skybox F5S however i am only getting sound but no picture on Nicktoons and Nick Jnr, is there a fix for this?
    im also using AJ's latest channels list.
    Your help is appreciated.
  • bigade1
    • Oct 2013
    • 340
    You're in luck because I can solve this issue for you. Select one of the affected channels on your box e.g Nick Jnr. Then using your remote control enter the menu settings, navigate to the installation section, then scroll down and press TP List. Once you've done this you will find the affected transponder already highlighted in red, hit the blue button and then the OK button to search the transponder and wait until the task has completed. When you exit the menus select the affected channels and you will find that the problem is resolved. This has been an ongoing issue for several weeks and it's due to the wrong FEC setting being used in AJ's lists.
