Skybox f6 ( clone ) ? copyright check
  • keithy1810
    • Nov 2014
    have a skybox f6 probally a clone that has come up with the message copyright check
    never updated firmware or anything it switched on and had the error, have searched the forums and tried to reflash with .bin wont do it check error at 100%
    Anyone have any idea ho to fix ?
    Thanks in advance keith
  • royalsat
    • Apr 2014
    • 16
    SkyBox | SkyBox
    Have a look at above link,this might help you?
    • mahrkpat
      • Jun 2012
      • 510
      Credit goes to bobby123 from another forum for this
      OPENBOX X5 & Skybox F6 Recovery
      1. Format USB drive to FAT32 file format
      2. Create a folder named "recovery" on the USB drive
      3. Copy KD_P9000E_HD.bin file to the recovery folder on the USB drive.
      4. Connect the USB drive to the USB Port on the satellite receiver.
      5. Turn the power on the satellite receiver while pressing the OK button on the front panel.
      6. Keep the OK key pressed until showing Lxxx message on the LED of the front panel.
      7. On the TV screen it should show that the software is updating by the USB drive.
      8. The STB should now restart hopefully all should now be working
      • Starman245
        • Jul 2015
        Thanks for the post mahrkpat, how do I change the rar file to bin file.
        • clusters
          • Mar 2015
          • 8248
          You need to extract the .bin files from the rar file, use winrar or 7zip. They open fine for me.
          Please DO NOT PM me asking for help.
          Post in the forum, that is what it is here for.
          • Starman245
            • Jul 2015
            Thanks clusters, I got to change to bin file and followed steps. F6 display loaded up to U100. Then " Check Error . Try again " I tried a few times and still Check Error. Any idea what to check in "Check Error"?.
            • P&D
              • May 2010
              • 2686
              Sounds like user error to me
              Unpack & load the flies below on to your USB stick then follow the info at the top
              • Grzany99
                • Jul 2015
                dont work showing error
