(Help) Using TPLINK ETHERNET POSSIBLE?
  • whelan189
    • Nov 2014
    have a openbox f5s, my router is way away from where tv is however dont wanna use wifi adapter cause of weak signal, have a tplink power kit, however plugged it in and doesnt get ethernet, is there anything i need to setup in settings or something ? thanks
  • Nutsandbolts
    • Oct 2011
    • 1168
    hi you may need to change network settings from wireless to wired(cable) connection like some receivers. Make sure also that ethernet cable is properly connected.
    Regards
    • sexysam
      • Oct 2008
      • 209
      After plugging adapters into router and box, press reset buttons on adapters.All light should be green now on adapter
