skybox f3s
  • greatone3000
    • May 2013
    • 61
    skybox f3s
    hi my box keeps rebooting when it reaches 100 it does it again is that a firmware problem
    cheers
  • pappafoz
    • Jul 2013
    • 18
    Maybe you need to read this 'sticky' - http://www.digital-kaos.co.uk/forums/f184/recover-dead-skybox-openbox-flash-using-serial-rs232-null-modem-cable-233298/
    • greatone3000
      • May 2013
      • 61
      got the lead just not got the port on comp
      cheers
      • pappafoz
        • Jul 2013
        • 18
        Borrow an older comp or lappy off a friend for an hour
        • greatone3000
          • May 2013
          • 61
          cheers nate
          • Hadron
            • 2102
            Before flashing the firmware, if you haven't already tried it, boot the box with the LNB cable removed. It may be a short circuit in the LNB lead.
            It could also be due to a failing PSU. If you have another PSU with the same voltage & polarity, & with the same or greater current (amp) rating, then give that a try.
            • freakazoid789
              • Dec 2010
              • 89
              happened to me, but i didnt upgrade firmware, just the channel list so beware, keep a null cable handy
